I am trying to install MATLAB R2010b to Ubuntu 12.04. I have the ISO file. First I copied it to my PC and then extracted it. Now it seems like I should run the install script. But I could not do that.
Here is the beginning of the install script to give you an opinion if it is not a script and I am doing something wrong:
#!/bin/sh
# Name:
#    install -  script file for invoking the Multi-platform installer on Linux.
#    Usage: install [-h|help]"
#                              [-javadir <directory>] | [-root <directory>] |"
#                              [-test] | [-v|-verbose]"
#                              -h|-help        - Display arguments."
#                              -test           - Don't actually run the java
#                                                command (only useful with -v)."
#                              -v|-verbose     - Display settings."
#                              -javadir <directory>       - Override default java     root directory."
#                              -root <directory>          - Override default DVD root directory."
#              The default settings when no override inputs are supplied are: "
#              -root = <directory containing this script>/../"
#              -javadir = <root>/java/jre/$ARCH/jre'
# Copyright 2009-2010 The MathWorks, Inc.
How can I run this script? I tried to rename it as install.sh and then tried
 $ ./install.sh
from the command window but I got the following error:
root@ghostrider:/home/zero/Downloads/R2010b_UNIX# ./install.sh
Preparing installation files ...
Installing ...
./install.sh: line 562: /tmp/mathworks_7799/java/jre/glnx86/jre/bin/java: Permission     denied
Finished
Am I doing something wrong? Could you please help me?
Regards
Jorge Castro
  • 73,717
Amadeus
  • 717
Assuming that image is named R2015b_glnxa64.iso, simply mount ISO:
sudo mkdir -p /media/iso
sudo mount -o ro,loop ./R2015b_glnxa64.iso /media/iso
run the installation script:
sudo /media/iso/install
and finally unmount image:
sudo umount /media/iso
Tombart
  • 999
You need to give executable permission to sys/java/jre/glnx86/jre/bin/java.
Eliah Kagan
  • 119,640
psukys
  • 3,670
You need to mount an ISO and then install it according to the set up instructions:
Jorge Castro
  • 73,717
