I try to install ocatve 3.4 under Ubuntu 10.04 to be able to work in eclipse. I followed the link How to install the latest Octave I have an output:
~$ sudo apt-get install octave-3.4.3-64-bit
Reading package lists... Done
Building dependency tree
octave-3.4.3-64-bit is already the newest version.
The following packages were automatically installed and are no longer required:
  python-matplotlib-data ttf-lyx python-tz python-pyparsing
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
when I try to run octave I have:
~$ octave
The program 'octave' can be found in the following packages:
 * octave3.0
 * octave3.2
Try: sudo apt-get install <selected package>
I am not sure what I should do, I found there http://wiki.octave.org/Octave_for_GNU/Linux that 3.4.3 is the latest version for Ubuntu 10.04. I am not sure if I have to remove all packages, or set-up some path or do it in different way. Thanks for help
tomasz74
  • 278
click this http://ubuntuone.com/6iTsUm8xqX7rXDf3S6yfeM
open it with software center to install .
Raja G
  • 105,327
  • 107
  • 262
  • 331
