I have a USB modem that is identified in Linux (Ubuntu 12.04) with lsusb as
Bus 001 Device 003: ID 0572:1329 Conexant Systems (Rockwell), Inc.
How to talk to that device (e.g. with microcom etc?)? What dev device should I use? There is no /dev/ttyUSBXXX available and just one /dev/ttyACM0.
Peachy
  • 7,235
  • 40
  • 47
Alex
  • 1,115
6 Answers6
You can use cu.
$ sudo apt-get install cu
You can connect to your modem with:
$ cu -l ttyACM0
(with: ttyACM0 being the device /dev/ttyACM0) You should get a response:
connected
At this point you can use any of the standard AT commands such as to test dialing:
ATDT 123-456-7890
You should have your userid set to the group dialout for permission to access the modem.
You can exit the cu application with "~." (tilde dot).
You can find other Hayese commands at:
http://en.wikipedia.org/wiki/Hayes_command_set
L. D. James
  • 25,444
If by talk you mean send AT commands in the form
echo "ATi" > /dev/usbDev
try this: http://brunomgalmeida.wordpress.com/2012/04/06/send-at-commands-to-usb-modem/
Eric Carvalho
  • 55,453
Bruno
  • 46
Use minicom, socat or screen:
socat - /dev/ttyUSB1
minicom -D /dev/ttyUSB1
screen /dev/ttyUSB1
NOTE: I used real device name /dev/ttyUSB1 instead of fake /dev/usbDev.
pevik
  • 483
I believe the answer you're looking for is here: Using a USB winmodem with a Conexant driver in (K)Ubuntu 11.10 (Oneiric).
Important stuff (extracted from the site):
When I plugged a Conexant modem, I executed
lsusb
and it said:
Bus 006 Device 002: ID 0572:1300 Conexant Systems (Rockwell), Inc. SoftK56 Data Fax Voice CARP
so I knew that the HSF modem was recognized by the system.
As I had a previous internet connection, I upgraded the system
sudo apt-get update && sudo apt-get dist-upgrade
I checked that I had no previous Conexant drivers installed. For example: I executed
ls /usr/sbin/hsfconfig
and it said that that file did not exist; if it existed I would have thought that something was still installed.
I made sure that I had "gcc" and "make" ready, executing
sudo apt-get install gcc make
Then I executed those steps told there:
sudo -s
cd /lib/modules/$(uname -r)/build/include/linux
ln -s ../generated/utsrelease.h
ln -s ../generated/autoconf.h
exit
I prepared the files for the driver compilation, executing
mkdir ~/conexant_modem
cd ~/conexant_modem
and if I had a 64-bit operating system I executed
wget http://linux.dell.com/files/ubuntu/hardy/modem-drivers/hsf/hsfmodem-7.68.00.09x86_64oem.tar.gz
tar xzf hsfmodem-7.68.00.09x86_64oem.tar.gz
wget http://www.bargweb.net/images/2009/november/hsfmodem-7.80.02.05-DiacoEdition.zip
unzip hsfmodem-7.80.02.05-DiacoEdition.zip
cp -a hsfmodem-7.80.02.05-DiacoEdition/modules/imported/include/framewrk.h hsfmodem-7.68.00.09x86_64oem/modules/imported/include/framewrk.h
cp -a hsfmodem-7.80.02.05-DiacoEdition/modules/imported/include/osservices.h hsfmodem-7.68.00.09x86_64oem/modules/imported/include/osservices.h
else, if I had a 32-bit operating system I executed
wget http://linux.dell.com/files/ubuntu/hardy/modem-drivers/hsf/hsfmodem-7.68.00.09oem.tar.gz
tar xzf hsfmodem-7.68.00.09oem.tar.gz
cp -a hsfmodem-7.80.02.05-DiacoEdition/modules/imported/include/framewrk.h hsfmodem-7.68.00.09oem/modules/imported/include/framewrk.h
cp -a hsfmodem-7.80.02.05-DiacoEdition/modules/imported/include/osservices.h hsfmodem-7.68.00.09oem/modules/imported/include/osservices.h
A note for the curious ones: those "framewrk.h" and "osservices.h" files were the different ones between the directories "hsfmodem-7.68.00.09oem/modules/imported" and "hsfmodem-7.80.02.05-DiacoEdition/modules/imported".
If I had a 64-bit operating system I executed
wget http://www.linuxant.com/drivers/hsf/full/archive/hsfmodem-7.80.02.06x86_64full/hsfmodem-7.80.02.06x86_64full.tar.gz
wget http://www.linuxant.com/drivers/hsf/full/archive/hsfmodem-7.80.02.06full/hsfmodem-7.80.02.06full.tar.gz
A note for the curious ones: that file was the newest one in http://www.linuxant.com/drivers/hsf/full/downloads.php
And then, if I had a 64-bit operating system I executed
tar xzf hsfmodem-7.80.02.06x86_64full.tar.gz
rm -r hsfmodem-7.80.02.06x86_64full/modules/imported
cp -R hsfmodem-7.68.00.09x86_64oem/modules/imported hsfmodem-7.80.02.06x86_64full/modules/
tar xzf hsfmodem-7.80.02.06full.tar.gz
rm -r hsfmodem-7.80.02.06full/modules/imported
cp -R hsfmodem-7.68.00.09oem/modules/imported hsfmodem-7.80.02.06full/modules/
The next step was to clean the present directory.
rm -rf hsfmodem-7.68.00.09x86_64oem
rm -rf hsfmodem-7.80.02.05-DiacoEdition
rm hsfmodem-7.68.00.09x86_64oem.tar.gz
rm hsfmodem-7.80.02.05-DiacoEdition.zip
rm hsfmodem-7.80.02.06x86_64full.tar.gz
rm -rf hsfmodem-7.68.00.09oem
rm hsfmodem-7.68.00.09oem.tar.gz
rm hsfmodem-7.80.02.06full.tar.gz
Then I had to change some files to adapt them to work with the 3.0.0 version of the Linux kernel. If I had a 64-bit operating system I executed
cd hsfmodem-7.80.02.06x86_64full
xdg-open modules/GPL/serial_cnxt.c
cd hsfmodem-7.80.02.06full
and then a text editor was launched. I searched for the string
#ifndef FOUND_UART_REGISTER_PORT
and below I found the string
static DECLARE_MUTEX(cnxt_port_sem);
I deleted that last string, and wrote there
static DEFINE_SEMAPHORE(cnxt_port_sem);
and I saved and closed that file. I executed
xdg-open modules/osdiag.c
THIS_MODULE,
.ioctl    = diag_ioctl,
I deleted that string, and wrote there
.compat_ioctl = diag_ioctl,
xdg-open modules/osnvm.c
static LIST_HEAD(nvm_newinst_list);
static DECLARE_MUTEX(nvmelem_writelist_sem);
static DEFINE_SEMAPHORE(nvmelem_writelist_sem);
A note for the curious ones: the source of those changes in those files was http://www.openmamba.org/showfile.ht...l-2.6.37.patch
The user named Chiaseth helped telling those steps that I followed, this way:
  1. I executed
    xdg-open modules/osservices.c
#include <linux/smp_lock.h>
and I deleted that string, and wrote there
#include <linux/mutex.h>
DEFINE_MUTEX(os_mutex);  // Define a mutex
In that file I searched for the strings
unlock_kernel()
replacing all of them with
mutex_unlock(&os_mutex)
Also, in that file I searched for the strings
lock_kernel()
mutex_lock(&os_mutex)
  1. I executed
    xdg-open modules/osdcp.c
static spinlock_t dcp_lock = SPIN_LOCK_UNLOCKED;
replacing it with
static DEFINE_SPINLOCK(dcp_lock);
  1. I executed
static spinlock_t diag_lock = SPIN_LOCK_UNLOCKED;
replacing it with
static DEFINE_SPINLOCK(diag_lock);
  1. I executed
    xdg-open modules/osfloat.c
static spinlock_t fpstates_lock __attribute__((unused)) = SPIN_LOCK_UNLOCKED;
replacing it with
static DEFINE_SPINLOCK(fpstates_lock);
  1. I executed
static spinlock_t atomic_lock __attribute__((unused)) = SPIN_LOCK_UNLOCKED;
replacing it with
static DEFINE_SPINLOCK(atomic_lock);
  1. I executed
    xdg-open modules/GPL/oscompat.h
static spinlock_t tqueue_lock __attribute__((unused)) = SPIN_LOCK_UNLOCKED;
replacing it with
static DEFINE_SPINLOCK(tqueue_lock);
Finally... If executed
sudo make install
sudo hsfconfig
It asked "Where is the linux source build directory that matches your running kernel?", then I simply pressed the return key to accept the default answer. I also accepted the default answer in other questions.
Finally the command reported that
The /dev/modem alias (symlink) points to ttySHSF0
I executed
dmesg
and at the end I saw
[59190.782005] hsfengine: module license 'see LICENSE file distributed with driver' taints kernel.
[59190.782011] Disabling lock debugging due to kernel taint
[59192.564398] ttySHSF0 at MMIO 0x0 (irq = 0) is a Conexant HSF softmodem (USB-0572:1300)
[59192.600274] usbcore: registered new interface driver hsfusbcd2
[59194.416241] usbcore: deregistering interface driver hsfusbcd2
[59194.600064] usb 6-1: reset full speed USB device using uhci_hcd and address 2
[59194.811746] cnxthsf_DcpDestroy: units still active, waiting..
[59194.811764] cnxthsf_DcpDestroy: units still active, waiting..
[59194.811778] cnxthsf_DcpDestroy: units still active, waiting..
[59196.967466] ttySHSF0 at MMIO 0x0 (irq = 0) is a Conexant HSF softmodem (USB-0572:1300)
[59196.994150] usbcore: registered new interface driver hsfusbcd2
which meant, among other things, that the USB modem was detected at /dev/ttySHSF0.
Note: as they said in https://help.ubuntu.com/community/Di...Howto/Conexant: "do not delete or move the source tree [in our case: ~/conexant_modem] from your system after these steps, it will be required to uninstall and patch the driver."
I launched kppp (for example) and configured a new "connection", specifying that the modem was at /dev/ttySHSF0. You could also use a program like efax-gtk to send faxes through the modem.
Eric Carvalho
  • 55,453
LnxSlck
  • 12,456
  1. Ensure that your USB modem is properly inserted into any available USB port on your Ubuntu computer.
  2. Click the network icon and select Edit connections. This will launch Ubuntu's networking management utility.
  3. Select the name of the USB modem from the list of available connections, then click Properties.
  4. Click Enable this Connection to tell Ubuntu that you want to use this device to connect to Internet networks.
  5. Click OK. Your USB modem will now be properly connected to and configured in Ubuntu, and you can now use it to connect to the Internet.
Source of tutorial here
Frantique
  • 8,673
There are two software I know of you can use to send AT(Attention) commands to your modem one is Serial port terminal and other one is Cutecom.
