In Mac's OS X, if you hold Option while opening a file, the Finder window will automatically close (after opening the file). This works whether you double-click the file or use the keyboard shortcut (Command+o). Is there an equivalent in Nautilus?
Asked
Active
Viewed 730 times
Yes you can, its actually very simple.
Install CCSM if you don't already have it.
In the 'commands' section of ccsm assign the command 'close nautilus' to the keybinding you want and there you have it. VERY SIMPLE AND POSSIBLE!
In this case your keybinding would be the 'option' key and left click mouse button, just like Mac OSX
GoOnGetErDone
- 600
From the command-line, somewhat similar behavior is possible.
I tried with nautilus but it doesn't support the 'quit' option with 'URI's (folder paths etc) but thunar does support that. So the below would open the file specified in its associated editor without starting thunar.
thunar -q myfolder/myfile.properties
Let us know if this helps.
Horizon
- 281
- 1
- 7
