156
I am having a problem that doesn't seem to be common based on searching various forums.
I cannot run the Make command.
Message:
The program 'make' is currently not installed. You can install it by typing:
sudo apt-get install make
So do this:
Reading package lists... Done
Building dependency tree
make is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
But then when I try to run Make I get the same message. What's up?
Edit: Ubuntu 12.04 64bit Desktop fresh install.
shgnInc
  • 4,431
snoopdogg
  • 1,561
6 Answers6
195
Run this command to install make and all the packages needed to build your code.
sudo apt-get install build-essential
JorelC
  • 2,053
74
Probably it is due command make is not present in system PATH, so remove and reinstall it.
sudo apt-get install --reinstall make
Tachyons
  • 17,455
12
Run command:
sudo apt-get update
to update package lists. After this,
d a i s y
  • 5,551
First you should update your packages and then install "make".
sudo apt-get update
Omega
I was coming from a background of installing WSL2 just today and was surprised to find that packages like make weren't already there, as I was so used to them being.
Then I realized my Ubuntu is a bit of a "clean slate". So I decided to update it to get essential development packages as per 'standard' recommendation, I guess:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get autoremove
Source: https://www.sitepoint.com/wsl2/
Edit: Install pip, too!
Run
Before running make, you might also need to generate a Makefile first.
Run
./configure
Then the make command
