I want to copy the default tmux.conf file to my home directory, but I can't find the location in Ubuntu 12.04. The man page states that the file resides at /etc/tmux.conf however this does not match with my setup.
You can use the current (default) settings as a starting point:
tmux show -g | cat > ~/.tmux.conf
Note the pipe to cat is required for now because of a known bug when redirecting tmux stdout to file.
- 1,031
As per dpkg -L tmux which shows you what files the package installed, there is no default tmux.conf included in the package. /etc/tmux.conf is just a location that you may use (only makes sense with multiple users using tmux) that will be evaluated before ~/.tmux.conf. You have to create your own .conf file. Have a look at this for example (first hit on google):
https://web.archive.org/web/20160308115847/http://dev.gentoo.org/~wired/conf/tmux.conf
The top answer's tmux show -g | cat > ~/.tmux.conf did not work for me since I got a bunch of unknown command errors.
Upon further digging it has to do with the syntax change so tmux show -g no longer generates valid config files. You must prepend every line with set -g in order for this to work or run:
tmux show -g | sed 's/^/set -g /' > ~/.tmux.conf
- 377
There is no default /etc/tmux.conf file. You can start with the example conf files in /usr/share/doc/tmux/examples, or look at the manual/web/etc. to come up with your own configuration file.
The examples directory contains:
/usr/share/doc/tmux/examples/n-marriott.conf /usr/share/doc/tmux/examples/t-williams.conf /usr/share/doc/tmux/examples/vim-keys.conf /usr/share/doc/tmux/examples/h-boetes.conf /usr/share/doc/tmux/examples/screen-keys.conf
- 141,990
Updated version of Daniel (2013) answer
tmux start \; show -g | sed -e 's/^/set -g /' > ~/.tmux.conf
GNU screen compatibility
If you just need to add GNU screen compatible key prefix (CTRLa) as described in vijay's answer
tmux start \; show -g | sed -e 's/^/set -g /' -e 's/prefix2 none/prefix2 C-a/i' > ~/.tmux.conf
new location of the config
In current versions of Ubuntu you could also store the config file in ~/.config/tmux/tmux.conf see tmux change log for version 3.1
mkdir -p ~/.config/tmux/ ; tmux start \; show -g | sed -e 's/^/set -g /' -e 's/prefix2 none/prefix2 C-a/i' > ~/.config/tmux/tmux.conf
regarding Ubuntu 12.04
The original answer was this:
tmux show -g ; cat > ~/.tmux.conf
However Ubuntu 12.04 supposedly had tmux 1.7 (citation needed). Therefor "the list-keys format so that it shows the keys using actual tmux commands which should be able to be directly copied into the config file" ( per tmux change log) has been added at least since tmux version 1.5 which means, that the above original command should not have been working in Ubuntu 12.04 ¯\_(ツ)_/¯
improvements in this answer:
- incorporates Alex H's answer using
set -g - circumvents issue with
no server running on /tmp/tmux-1000/defaulterror - ignore case in
sed - alternative path
~/.config/tmux/tmux.conf(not Ubuntu 12) - detailing the changelog-archaeology
Note:
I actually tried to edit the top answer, but it was rejected as it incorporates changes not present in the original answer.
- 151
- 5
Even the command in this answer leaves syntax error in conf file.
/users/kube/.tmux.conf:35: bad key: none
I suggest below command:
tmux show -g | sed -e 's/^/set -g /' -e 's/prefix2 none/prefix2 C-a/g' > ~/.tmux.conf
This solves two problems
- The syntax issue.
- It allows to use extra bind-key Controla which is easy to type than Control+b
- 207,228
- 111
The config file is located in /usr/share/tmux, not in /usr/share/doc/tmux.
- 13,500
- 1
