I put together an ubuntu 12.04 server a couple of weeks ago and everything seemed fine until this morning.
Suddenly, I'm having trouble installing new packages - at first I thought there was something wrong with tinyproxy and so I tried installing squid instead. However, I get similar results:
Starting tinyproxy: tinyproxy: Could not open config file "/etc/tinyproxy.conf".\
/var/lib/dpkg/info/squid3.postinst: 1: /var/lib/dpkg/info/squid3.postinst: cannot open /etc/squid3/squid.conf: No such file
It seems that apt-get is not creating the configuration files needed for these programs.
I haven't modified any configuration or user groups since the last successful update/install of packages.
/etc is present, and is populated with a nice healthy tree of configuration files. It is owned and grouped to root, and has the properties drwxr-xr-x - all the files and folders inside seem to be fine to, as far as I can tell. I've even been able to edit/save a couple as sudo.
Full output from installing tinyproxy:
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
tinyproxy
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/61.6 kB of archives.
After this operation, 201 kB of additional disk space will be used.
Selecting previously unselected package tinyproxy.
(Reading database ... 58916 files and directories currently installed.)
Unpacking tinyproxy (from .../tinyproxy_1.8.3-1_amd64.deb) ...
Processing triggers for ureadahead ...
Processing triggers for man-db ...
Setting up tinyproxy (1.8.3-1) ...
invoke-rc.d: initscript tinyproxy, action "start" failed.
dpkg: error processing tinyproxy (--configure):
subprocess installed post-installation script returned error exit status 70
tinyproxy
A suggestion from a friend was to check the downloaded package in /var/cache/apt/archives. There is an entry for /etc/tinyproxy.conf
Running sudo touch /etc/tinyproxy.conf generates an empty file owned by and writeable to root.
Result of strace after installation:
18467 open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
18467 open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
18467 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\30\2\0\0\0\0\0"..., 832) = 832
18467 open("/etc/tinyproxy.conf", O_RDONLY) = -1 ENOENT (No such file or directory)
I was able to work around the problem by copying a config from another server and setting it up for the new one - but this is not exactly ideal.
