I am new ubuntu user and try to install gnu typist. I need to compile the source code to run the app. According to documentation i need c compiler to compile the source code.
I don't have idea how to compile the source code and start using the app on ubuntu/linux.
Please help me to migrate on ubuntu/linux from windows?
mahesh
  • 163
If you do want to compile it for any reason, download it and do the following:
cd Downloads/
tar -xvf gtypist-2.8.3.tar.gz
cd gtypist-2.8.3/
./configure
make
sudo make install
The last three lines are the important bit, the first three are just changing to the directory where it's been downloaded to, unpacking the archive and changing to the directory where it's been unpacked to.
Please, before you do, carefully read the INSTALL file that comes with the program, and see if you needn't do something different. You should in any case, if you don't have a very good reason not to, install it from the Repositories as Takkat suggests.
Zanna
  • 72,312
For a new Ubuntu user there usually is no need to compile applications from source. However this can be done.
In your case I would strongly recommend you install Gnu Typist (or gtypist which is the same) through the software center or synaptic.
Takkat
  • 144,580
