I can't get BOINC to start with the rest of the startup applications and the software itself doesn't have that option, I've been reading about it on Berkeley's forum but I can't get the answer, it appears the 12.04 version has a lot of errors that the previous version didn't. Is there a way to do it?
I was wondering the same thing, but then yesterday used System Monitor, and there is a Process running (Einstein@Home IIRC, grinding away at some data), so the BOINC Manager doesn't have to be obviously running for BOINC to be happening.
Check that, you might be just fine!
- 11
Just enable service. Example for Ubuntu:
sudo systemctl enable boinc-client
If this not working, open config - /etc/default/boinc-client you'll see startup script path:
/etc/init.d/boinc-client
check out if this file exists and value of ENABLED variable (should be "1" in both files).
To start service manually:
/etc/init.d/boinc-client start
Also you can add boinc client binary (e.g. /usr/bin/boinc) to startup applications. Path depends of you distro, can be found in files mentioned above.
- 180
try with bum , a good startup manager .open your terminal and type this
sudo apt-get install bum & sudo bum
by selecting you can manage your startup services ,:D
hope that helps
- 105,327
- 107
- 262
- 331
