19
I'm very new to Ubuntu. I'm looking at the directory /usr/include it contains lot of header files. I know they have specified certain constants and other information that are used in Ubuntu. I'm confused with the use of it.
One of the directory inside is linux/byteorder. Which has two files:
big_endian.h  little_endian.h
I wonder why two files are needed? My machine will be either big endian or little endian right? Didn't ubuntu while installation didn't pick my system byte order? Does /usr/include is just same for all machines? What is the exact use of it?
Thanks in advance.
batman
  • 8,071
That folder includes the header files for C compilers. Such as "stdio.h", "stdlib.h" etc.
When you type header information in the C source file such #include <stdio.h> the compiler will look for the file in /usr/include directory by default.
big_endian.h and little_endina.h files are included, because though your computer may be of only one kind, you can cross-develop application for both architecture. So, you need both header file.
Anwar
  • 77,855
These files are needed when you compile programs, be that a software package you need to compile manually or your own programs. They are included in the C code such that you can use the functions defined there. Don't worry about them if you don't code.
January
  • 37,208
Yes but you may decide to develop a cross platform app.
And when you write program for the other machine which is different endian than yours. Then may be these files are used to compile such programs. :)
Sam
  • 1,009
