I've installed phpmyadmin sudo apt-get install phpmyadmin. Of course, I have also mysql and a web server running properly.
Now how can I reach it?
Did you try http://localhost/phpmyadmin?
Edit: Do this first
sudo nano /etc/apache2/apache2.conf
add this line somewhere
Include /etc/phpmyadmin/apache.conf
and finally restart apache.
sudo service apache2 restart
You probably skiped the configure from the package.
Try this cli:
sudo dpkg-reconfigure phpmyadmin
And when it choose the webserver to configure, select apache.
It depends on your configuration.
From my experience, I may reach with localhost/phpmyadmin but fail to login, I have to reconfigure phpmyadmin, reset MySQL password, and then I may login without problems.
sudo dpkg-reconfigure phpmyadminunix socketrootmysqlsamplepasswordrootphpmyadminapache2sudo dpkg-reconfigure mysql-server-5.5mysqlsamplepasswordmysqlsamplepasswordBut if your problem is fail to interpret php, follow the instruction to enable your php first.
sudo gedit /etc/apache2/mods-available/php5.conf# in front of php_admin_value engine off to disable it.sudo /etc/init.d/apache2 restartWish it helps!
Have a nice day!
If you have changed the port in which Apache is listening on, default is 80;
sudo nano /etc/apache2/ports.conf
look for the Listen port should look like
Listen 80
if that port is diffrent in order to get into phpmyadmin your url must point to that port
example
localhost:port/phpmyadmin/
change the port number to the one you have in the /etc/apache2/ports.conf
