The question is simple.
What would be the script I would have to use to shut down a computer in my network thru ssh.
Normaly i would go to command line and:
ssh desktop
delik@desktop's password:
delik@desktop:~$ sudo shutdown -P 0
To power on I created a file and wrote:
wakeonlan xx:xx:xx:xx:xx:xx
And gave it the executable bit
That way to power on it requires only a double click. Would i be capable of doing the same to shutdown?
DeLiK
  • 352
  • 16
For the following I am assuming that the user you are going to use in remote-host is the same you use in local-host.
In order to do what you want, you have to first authorize your local-host to connect to you remote-host with no password. To do that you have to (as described here):
  1. Install ssh:
    sudo apt-get install ssh
  2. Create public and private keys using ssh-key-gen on local-host by entering this command in your localhost:
    ssh-keygen
    You should save the generated key in:
    /home/yourusername/.ssh/id_rsa
    Press enter twice to leave the passphrase empty.
    Your identification has been saved in /home/yourusername/.ssh/id_rsa.
    Your public key has been saved in /home/yourusername/.ssh/id_rsa.pub.
    The key fingerprint is:
    XX:XX:XX:xX:XX:xX:XX:XX:XX:XX:XX:XX:XX:XX yourusername@local-host
  3. Copy the public key to the remote-host using ssh-copy-id:
    yourusername@local-host$ ssh-copy-id -i ~/.ssh/id_rsa.pub remote-host
    yourusername@remote-host's password:
    Now try logging into the machine, with:
    ssh remote-host
    and check in .ssh/authorized_keys to make sure we haven't added extra keys that you weren't expecting.
    Note: ssh-copy-id appends the keys to the remote-host’s /home/yourusername/.ssh/authorized_key.
  4. Login to remote-host without entering the password:
    ssh remote-host
    yourusername@remote-host:~$
    Access to remote-host with no password. Success!
Now you have to be able to execute sudo shutdown -P 0 with no password. You can do that by modifying /etc/sudoers on remote-host with visudo. That way, user yourusername can execute the shutdown command with no password asked.
  1. Login to the remote-host:
    ssh remote.host
  2. Run:
    sudo visudo
    By running visudo, you edit /etc/sudoers in a safe manner.
  3. Add this line to the file:
    yourusername ALL = NOPASSWD: /sbin/shutdown
  4. After doing that, get back to your local-host, create a new empty file and paste this line, modifying the remote-host's name:
    ssh remote.host sudo shutdown -P 0
  5. Save and close the file, right-click on it to go to its PropertiesPermissions, and tick Execute this file as a program.
Script done!
DeLiK
  • 352
  • 16
For me on my 18.04 server, the keygen and sudoers edits did not work on their own. Finally, after a big hassle, I managed to remote shutdown my server with the following command:
plink -batch -ssh -P 222 -t user@server -pw XXX "sudo -S shutdown"
I edited sudoers so that:
user ALL=(ALL) NOPASSWD:/sbin/shutdown
Jabin
You can use an user-account with a keyfile instead of a password (so you don't have to type in the password to login). You can also give the user a "default shell" that is not bash or sh, but "shutmedown.sh" or something like this, which will exec your shutdown-code.
mene
