Possible Duplicate:
DVD with both 32-bit and 64-bit Ubuntu
I have both 32 and 64 bit Ubuntu 12.04 iso, but how can I integrate them (both 32 bit and 64 bit) into a single DVD with a menu to choose from two options Clearly written like "1. Install Ubuntu 12.04 32 bit" and "2. Install Ubuntu 12.04 64 bit" and also without losing the Live Mode
Namshum
  • 1,825
  • 25
  • 32
I don't know of a program that will allow you to do it in Ubuntu. But just from past exprience, I think that it can be done with scripting. If you're not comfortable with that, pendrivelinux.com has a utility that will allow you to accomplish just that. It called XBOOT. Once you create the USB, you can then put it on a DVD.
XBOOT is yet another neat little Multiboot ISO USB Creator. It is a Windows based application that can be used to create a Live Multiboot USB or even a Multiboot ISO file that can then be burnt to a CD/DVD. XBOOT supports many Linux Distributions and Utilities, and allows you to use your choice of a Grub or Syslinux bootloader. Also included is a built in QEMU emulator (enabling you to boot an ISO from within Windows).1
Click to download
1Source:PenDriveLinux
Mitch
  • 109,787
