Running: Linux ips-svf-1 3.0.0-22-server #36-Ubuntu SMP Tue Jun 12 17:56:20 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
I'm trying to free space in /boot with apt-get -y purge, but every time I run the command I get an error about unmet dependencies:
sudo apt-get -y purge linux-headers-3.0.0-12
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-headers-3.0.0-12-server : Depends: linux-headers-3.0.0-12 but it is not going to be installed
linux-image-server : Depends: linux-image-3.0.0-26-server but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
However, I can't run apt-get -f install since /boot is full.
I also tried running dpkg --purge and dpkg --remove manually, but both give the same unmet dependency error.
Any suggestions on how I can successfully free space in /boot? Is there anything I can safely delete with rm?
