Why might sudo chmod -R a+w * cause
sudo: /etc/sudoers is mode 0640, should be 0440 sudo:
no valid sudoers sources found, quitting
and how might it be made to work?
Why might the command cuase this to happen? I suspect you ran the command while your current directory was /etc!
sudo refuses to work if the permissions of /etc/sudoers have been tamprered with to avoid compromising the system. You will have to fix the permissions using recovery mode unless you have another way of getting root access.
