I had issues with WiFi so I removed Network Manager.
I booted Windows OS (dual booting Windows 7 and 12.04) to download wicd 1.7.2.4. Extracted it and installed. However, wcid worked properly with Wired Connection but could not connect to WiFi. So, I re-installed Network Manager which works properly now, and wicd connects to WiFi too.
As soon as I disconnect from Network Manager, wicd connects only to wired. At this point, I wanted to remove wicd but apt-get returns no wicd installed, can't see it in Synaptic or Software Center, but only in Applications list under Dash home.
Of course wcid icon shows connections, and resulting connected, so my system shows both applets for wicd and network manager in the top panel. When running dpkg commands, wicd is not listed as installed package.
Any suggestion how to remove wicd? Consider that I started with Ubuntu just few months ago so my knowledge base is limited.
Peachy
  • 7,235
  • 40
  • 47
danijelc
  • 898
have you installed it from source? you can't use synaptic or software center to remove wicd then.
By the way, you should look for a startup script, to remove wicd from startup. Then you will not need to uninstall, it won't get started if you remove it. Check /etc/rc5.d and /etc/xdg/autostart for entries. (I assume you boot to gui)
Since I also had problems with Wicd + NetworkManager, it had to be decided which one will disappear from the OS, as it seems both interfaces do a sloppy job when it comes to deal with dependencies and side effects.
First I decided to remove Wicd, and that should match your question (then I tried Wicd without NM, but that's another story...).
Normally, if installed from a package (apt-get), the line
sudo apt-get purge wicd
should be enough. If not, and installed from the source, there is a uninstall.sh in wicd-dir/ source code dir that should fix the uninstallation. If not...
  1. the theory wants that editing
    /etc/default/wicd
and set START_DAEMON=no would be enough of a job to just stop the process and family from starting. But it's not enough. So... when a program is tied to several places that don't rely on a single config file, I remove it completely: (it's also linked to my own gnome configuration, and yours may vary)
  1. ensure the init program does not run
That's basically in /etc/rcX.d. All the S20wicd can be renamed K00wicd automatically, thanks to a script like rcconf.
And now remove the crumbs...
  1. move the desktop autostart stuff
Something like
mv /etc/xdg/autostart/wicd-tray.desktop /etc/xdg/wicd-tray.desktop.donotstart
  1. dbus
Similar to the above
mv /etc/dbus-1/system.d/wicd.conf /etc/dbus-1/wicd.conf.donotstart
And reboot, wicd should be quieter.
Again depending on your settings, the files could be somewhere else in /etc.
Do a find /etc -iname "*wicd*" to find where they're likely to sit.
Déjà vu
  • 1,089
