I've been getting this annoying problem. I want to compile a .so under Ubuntu using the Anjuta IDE. It compiles fine and all, but when I load it, that's when the error comes up:
/usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15' not found
I've tried everything in GLIBCXX_3.4.15 not found. But nothing seemed to work.
have you tried adding the /usr/lib/x86_64-linux-gnu to the LD_LIBRARY_PATH environment variable?
I did and worked. Let me know if this helps.
Joaquin
  • 41
