I use Ubuntu Precise Pangolin 12.04.
I installed TV Maxe using the commands below:
sudo add-apt-repository ppa:venerix/blug
sudo apt-get update
sudo apt-get install tv-maxe
How do I completely uninstall TV Maxe ?
Thank you.
Using PPA-Purge
sudo apt-get update
sudo apt-get install ppa-purge
sudo ppa-purge ppa:venerix/blug
sudo apt-get update
Manual Uninstall
Type the following in this order into your terminal:
sudo apt-get update
--> updates the apt-get database
sudo apt-get remove --purge tv-maxe
--> removes the package tv-maxe including config files
sudo apt-get autoremove --purge
--> removes leftover packages that were installed as dependecies including config files
sudo add-apt-repository --remove ppa:venerix/blug
--> removes the software repository from the software.sources list
sudo apt-get update
With both methods there might still be some configuration files left in your home directory. In order to remove them you will have to head to your home directory, hit Ctrl + H to display hidden files and search for any entries related to tv-maxe.
Edit: As gertvdijk has pointed out, ppa-purge is the better option here because of the external PPA.
What you want is 'purging' the PPA.
See "How to purge a PPA" in this blog article on how to do that. This is generic for reverting upgrades done via a PPA.
I recommend doing this over just removing the PPA and removing the packages you think you have installed from it (as per the first part of the answer of @MHC). Here's why:
Purging a PPA means not only to disable the PPA, but also to downgrade any packages you've upgraded from that PPA, to the version available in the official Ubuntu repositories.
So, also upgraded dependencies will be reverted to use the 'official' ones again.
