Software that I'm installing requires /lib/libc.so.6, but it's not in place:
$> ls -l /lib/libc*
lrwxrwxrwx 1 root root      14 2011-10-09 06:02 /lib/libcap.so.2 -> libcap.so.2.20
-rw-r--r-- 1 root root   18832 2011-02-16 03:42 /lib/libcap.so.2.20
-rw-r--r-- 1 root root 1620736 2012-05-23 07:19 /lib/libcrypto.so.0.9.8
libc and libc6-dev are installed. Running apt-get upgrade glibc does not solve this.
What should I do to resolve this dependency?
user13871
  • 237
A quick solution.
Open a terminal (Ctrl+Alt+T) and run the following commands:
For 64-bit Ubuntu:
sudo ln -s /lib64/x86_64-linux-gnu/libc.so.6 /lib64/libc.so.6
For 32-bit Ubuntu:
sudo ln -s /lib/i386-linux-gnu/libc.so.6 /lib/libc.so.6
green
  • 14,406
On my 64-bit Ubuntu it needed to be:
sudo ln -s /lib/x86_64-linux-gnu/libc.so.6 /lib/libc.so.6
(i.e. the 64 bit library is below /lib, not /lib64)
you need to run
sudo apt install ia32libs
I was facing the same issue..... Try this command: sudo apt-get install lib32z1
