68
In Ubuntu 11 I just dragged the folder there. This seems to be not possible on my new Samsung ultrabook with Ubuntu 12.04
enter image description here I've tried Ctrl+D and using the top menu but nothing happens and no error messages, just nothing.
How can I add a bookmark?
6 Answers6
78
Got same ergonomic problem!
Ctrl+D or Add Bookmark will function only when "desired link folder" is selected on Location Bar. "Bookmarks" will appear only on Places (Nautilus) after placing one bookmark. Not so friendly IMO...
References: "Adding a Bookmark
To add a bookmark, open the folder or location that you want to bookmark, then choose Places->Add Bookmark.
If you are using a Nautilus browser window, choose Bookmarks->Add Bookmark." From: http://linux.about.com/library/gnome/blgnome6n6p.htm
And http://ubuntuforums.org/showthread.php?t=2027355
And finally, Help from Ubuntu: Ubuntu Desktop Guide » Files › Tips and questions » Edit folder bookmarks
This is almost duplicated from: Nautilus bookmarks do not appear at all ?
Cormano
  • 781
24
What you can do is to edit bookmarks by pressing Ctrl+B and change the url of a bookmark that already exists (and if you want you can change the name too). Then the new one that you wrote will appear and the one that you "replace" will be created by ubuntu again. I think that this is an error too but you can fix your problem
green
  • 14,406
gdfesta
  • 288
Once you add your first bookmark using Ctrl+D, bookmarks will appear on the Nautilus tab and you will be able to use drag and drop. Seems to be a bug rather than a feature. However, I had some problems with that as well.
January
  • 37,208
This issue is fixed with the new updates.
Now Bookmarking works smooth, by using Ctrl+D.
green
  • 14,406
Anoop K P
  • 306
Ubuntu 18.04 is what I am using, I add this answer because it appears in google search but the solutions provided were not as intuitive. And this is the visual approach. CTRL+D does work but...
I normally drag the folder into the explorer menu on the left. However this was not possible specifically with the root folder.
So I had to find the solution to the problem above, which was very simple once I found it.
Navigate to ROOT and then use the middle button (with plus symbol, above 100%) in this picture to create the bookmark, this would add the current folder to the left-hand folder explorer.
TheArchitecta
  • 321
It's very easy just press Ctrl + B and then edit the directory!
Aditya
  • 13,616
Alecs
  • 31
