Is it possible to add to or edit the Session Indicator menu items?
Is there an easy way to do this, or would it involve recompiling a custom build?
I cannot find much relating to this online.
Eliah Kagan
  • 119,640
jaypeagi
  • 113
some refs:
- jimi312 / Titlebar Menu / source — Bitbucket:
- Programming with DBus using PyQt
- Unity/QA/StateIntrospection - Ubuntu Wiki: especially example code
At the moment passive querying can extract information such as shown in this post:
How does one find out which application is associated with an indicator icon? .
I am also exploring the answer to this question as it relates to DBus, to use as high a level interface as possible to avoid low level programming. The ultimate objective is to create a utility that minimally identifies the host applications of the indicators and the sub-apps of their component menus. Maximally it would allow modifications to the menus such as the session-indicator menu including the top level menu, ie. the icon indicator of the unity-panel itself.
It would be good to know which, (if any!) modifier methods exist in the DBus environment to modify the DBus, so the indicator panel and it's components, such as Session Indicator, could be modified as you require.
The following commands reveal the interface methods to manipulate the session indicator bus information but unfortunately the parameters used in these methods are not described here - the reference above supplies links to the documents describing the general indicator interfacing - but specifics for the session indicator are still needed.
The output from
qdbus --session  com.canonical.indicator.session
implicates the existence of menu interfaces as the items below:
/org
/org/ayatana
/org/ayatana/indicator
/org/ayatana/indicator/service
/com
/com/canonical
/com/canonical/indicator
/com/canonical/indicator/users
/com/canonical/indicator/users/menu
/com/canonical/indicator/session
/com/canonical/indicator/session/service
/com/canonical/indicator/session/menu
The interfaces can be examined with:
gdbus introspect --session --dest com.canonical.indicator.session \
                 --object-path /com/canonical/indicator/users/menu --recurse
and
                 --object-path /com/canonical/indicator/session/menu --recurse
Note the internal reference to interface com.canonical.dbusmenu.
For a real comprehensive dump use:
gdbus introspect --session --dest com.canonical.indicator.session --object-path / --recurse
Several sub-apps are bound to the session indicator drop down menu but what is not clear is whether these interface methods just transfer data to the associated sub-menu apps or whether in fact there is a communication channel to the session indicator app itself so its menu can be "methodized".
Also,
qdbus --literal --session  com.canonical.AppMenu.Registrar           \
                          /com/canonical/AppMenu/Registrar           \
                           com.canonical.AppMenu.Registrar.GetMenus  \
| sed -e 's/], \[/],\n[/g' | sort -k 4 -V
provides a list of interface menu associations (there are menusfor the windows and also for the indicators like the session indicator, which is which in the list below still needs determination)
[Argument: (uso) 25167301, ":1.22", [ObjectPath: /com/canonical/menu/18005C5]],
[Argument: (uso) 25165828, ":1.22", [ObjectPath: /com/canonical/menu/1800004]],
[Argument: (uso) 48234500, ":1.81", [ObjectPath: /com/canonical/menu/2E00004]],
[Argument: (uso) 55244411, ":1.114", [ObjectPath: /com/canonical/menu/34AF67B]],
[Argument: (uso) 55370996, ":1.114", [ObjectPath: /com/canonical/menu/34CE4F4]],
[Argument: (uso) 65083174, ":1.275", [ObjectPath: /com/canonical/menu/3E11726]],
[Argument: (uso) 65085474, ":1.275", [ObjectPath: /com/canonical/menu/3E12022]],
Examining
qdbus --session  com.canonical.AppMenu.Registrar /com/canonical/AppMenu/Registrar
it may be these methods are useful:
method void org.freedesktop.DBus.Properties.Set(QString interface_name, QString property_name, QDBusVariant value
method void com.canonical.AppMenu.Registrar.RegisterWindow(uint windowId, QDBusObjectPath menuObjectPath)
method void com.canonical.AppMenu.Registrar.UnregisterWindow(uint windowId)
Note the parameter identified as menuObjectPath. These method names are qualified with {un}RegisterWindow, so the methods perhaps are irrelevant to indicator menues.
Once the correct methods with their parameters are identified it is easier to use qdbus (cannot use QVariant parameters however) or D-Feet than gdbus to invoke the methods.
Basically qdbus and gdbus are functionally the same and use identical parameters except:
  • qdbus does not identify the separate components with --dest, --object-path, --method, ... but instead requires the corresponding attributes be given in exact order
  • gdbus method calls handle more parameter types
  • qdbus is not as exhaustive asgdbus especially w/ --recurse
  • qdbus can expediently extract its command parameter sequence via double or triple click from its output w/ a middle click to concatenate it to the end of the command
The answer
in the post mentioned above describes how to use qdbus as an expedient technique to compose the scripts.
The manpage man gdbus (or gdbus:) has a better exposition than man qdbus but consider D-Feet.
