I have a couple of computers that I manage using Canonical Landscape.
Both of them are behind routers and in different cities so I can't easily SSH into them using openssh. They're running Ubuntu 12.04 Desktop Edition. Can I use Landscape to SSH into the computers?
Jorge Castro
  • 73,717
Benjamin
  • 414
No, but you can use landscape to run commands on the box. You could (for example) run whatever you wanted to run via ssh, but as a script.
Another option would be to setup a reverse SSH tunnel via that script system.
So you could create a script to run on the landscape managed host which ssh'ed back to your home machine or some other publicly accessible IP:-
ssh -R2222:localhost:22 username@homeserver.example.com
You'd need an ssh key to already be generated without a pass-phrase on the remote machine and place the public part on 'homeserver' in ~/.ssh/authorized_keys as a pre-requisite to doing this.
Once that ssh tunnel is setup, you should be able to (on homeserver.example.com):-
ssh -P 2222 username@localhost
This will redirect ssh (on port 2222) from homeserver.example.com to port 22 on the remote host.
popey
  • 24,549
You currently cannot use Landscape as a remote console proxy, but it is one of the most-requested features, so it is in active consideration. If you want to provide more information on what your use case would be, that would be helpful -- I am gathering, getting around non-routable IPs and firewall(s) is your need?
0xF2
  • 3,155
