Terminal output:
name@name:~$ sudo apt-get install fglrx-updates
[sudo] password for name:
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 fglrx-updates : Depends: lib32gcc1 but it is not going to be installed
                 Depends: libc6-i386 but it is not going to be installed
Please give a simple answer as I may not understand very complex ones.
Braiam
  • 69,112
Your answer
If you have not installed lib32gcc1 & libc6-i386, to fix the dependencies problem you should use sudo gdebi fglrx*.deb instead of sudo apt-get install fglrx-updates.
The GDebi is a tool that install .deb packages and solve automatically the independencies problems.
It is only one way of many to solve this. I recommend you use it because worked for me.
Extra information
I had some problems with the fglrx installation, see My Question. It might be useful
Reference: fglrx Installation Guide
Lucio
  • 19,191
  • 32
  • 112
  • 191
