I'm running ubuntu 12.04 LTS and working with eclipse (juno) on a c++ project. I keep getting "TERM environment variable not set" in the console while trying to run the program. I realize this means the variable needs to get set. My question is what should it be set to and how do I set it?
I've read that it should be 'xterm' in a few places. So I added
export TERM=xterm
in my .profile and while eclipse stopped giving me the warning, instead it would output unreadable garbage everynow and then (not a side effect of the program). It did display the program output but intermixed were weird characters. This leads me to believe it's not 'xterm' I should be setting TERM to. Or I'm setting it in an incorrect way.
Any help is appreciated.
Sample output:
**TERM environment variable not set.**
Please make a selection
1. Create a budget
2. Edit a budget
3. Display a budget
4. Save a budget
5. Load a budget
6. Exit
What is your selection: 1
Enter the name of your budget:
etc
The program continues to execute as expected but the message is highly annoying
  • As someone has commented, I do use system("clear") which is likely the source of the warning? Either way, is this likely just an eclipse issue or something I can fix in ubuntu/linux
Robert
  • 91
"It did display the program output but intermixed were weird characters" How about posting the output?
The problem might be that Eclipse runs the program not inside of a regular terminal, but its own console. Did you try to run the program from regular terminal, outside of Eclipse?
My suspicion is that the Eclipse runs the program as if it was a non-interactive program, in a non-interactive setting, where the TERM variable is not needed. However, it might be that your program in fact uses a system call (something like system( "clear" )) that in fact requires the TERM variable in order to work.
Unfortunately, I never use Eclipse, so I'm just guessing.
EDIT: Yeah, that's the way it is: system( "clear" ) requires a terminal, but Eclipse does not provide terminal capabilities for your program. Solution:
(i) Run the program from command line in a terminal
(ii) Go to Eclipse settings and tell it to start the program using gnome-terminal. Apparently, there is a description how to do it here.
January
  • 37,208
