KDE Telepathy keeps getting in the way every time I try to use Empathy from the messaging menu. If I get a message, it opens in the KDE telepathy UI instead of in Empathy. This is rather frustrating as it causes a delay before it opens, and is not integrated with Empathy.
How can I stop this from happening? This still happens in 12.10 and I've had to remove the kde-telepathy packages. Is there a solution?
RolandiXor
  • 51,797
I figured out how to do this (Ubuntu 12.10):
Edit /usr/share/dbus-1/services/org.freedesktop.Telepathy.Client.KTp.TextUi.service to comment out (or remove) the link to ktp-text-ui and use Empathy instead.
In the end, the service file will look like this:
[D-BUS Service]
Name=org.freedesktop.Telepathy.Client.KTp.TextUi
# Exec=/usr/lib/kde4/libexec/ktp-text-ui
Exec=/usr/lib/empathy/empathy-chat
After this, I figured I had to restart dbus, but doing a
sudo service dbus restart
is evidently a bad idea, since it locks up everything.
So I suppose you have to log out and log back in (or reboot, which is what I ended up having to do).
shrikant
  • 288
There's a bug report on this issue here: https://bugs.launchpad.net/ubuntu/+source/ktp-text-ui/+bug/951104 There's a proposed solution on the last line, but I have to confess that I'm not entirely sure how to go about defining a preferred handler on dbus. (Since it's easy enough to remove the kde-telepathy packages without affecting the rest of KDE and I don't need two messaging clients, I just went with that option instead.)
