40
The following command signs me out (do not run this command):
kill -9 -1
I don't understand why.
Can someone explain this to me?
RolandiXor
  • 51,797
hytromo
  • 4,891
The syntax is kill SIGNAL PID.
The -9 option specifies that the SIGKILL signal should be sent (immediately terminate the target process(es), and specifying the PID -1 is shorthand for "all processes except itself and init".
Since you don't use sudo (and presumably don't have root permissions), this immediately kills all processes you have permission to kill - your entire session, hence logging you out.
chronitis
  • 12,647
27
try
man kill
to get an explanation of the kill command..
it says:
A PID of -1 is special; it indicates all processes except the kill process itself and init.
and
EXAMPLES
kill -9 -1
 Kill all processes you can kill.
I hope you understand why your computer will log you out, when you end all processes. You quitted everything.
Hope this helps.
mondjunge
  • 3,336
You are giving -1 as the process id: from the kill man-page:
BuZZ-dEE
  • 14,533
