I am trying hard! to update the gcc-msp430 compiler on my ubuntu, but it does not work (I guess because of the older version of the same compiler that is already installed). Here is the command I used as well as the output.
saeid@saeid-Satellite-C660:~$ sudo dpkg --force-all -i ~/Downloads/gcc-msp430_4.6.3~mspgcc-20120406-3_i386.deb; sudo apt-get -f install
[sudo] password for saeid:
(Reading database ... 164599 files and directories currently installed.)
Unpacking gcc-msp430 (from .../gcc-msp430_4.6.3~mspgcc-20120406-3_i386.deb) ...
dpkg: warning: overriding problem because --force enabled:
 trying to overwrite '/usr/bin/msp430-cpp', which is also in package msp430-gcc-tinyos 4.5.3-20110821
 trying to overwrite '/usr/bin/msp430-gcc', which is also in package msp430-gcc-tinyos 4.5.3-20110821
 trying to overwrite '/usr/bin/msp430-gcov', which is also in package msp430-gcc-tinyos 4.5.3-20110821
dpkg: gcc-msp430: dependency problems, but configuring anyway as you requested:
 gcc-msp430 depends on msp430mcu; however:
  Package msp430mcu is not installed.
 gcc-msp430 depends on binutils-msp430 (>= 2.21~); however:
  Package binutils-msp430 is not installed.
Setting up gcc-msp430 (4.6.3~mspgcc-20120406-3) ...
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
  binutils-msp430 msp430mcu
Suggested packages:
  msp430-libc
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/11.1 MB of archives.
After this operation, 57.1 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 164845 files and directories currently installed.)
Unpacking msp430mcu (from .../msp430mcu_20110613-3_all.deb) ...
dpkg: error processing /var/cache/apt/archives/msp430mcu_20110613-3_all.deb (--unpack):
 trying to overwrite '/usr/msp430/lib/msp430mcu.spec', which is also in package msp430mcu-tinyos 20110613-20110821
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Unpacking binutils-msp430 (from .../binutils-msp430_2.22~msp20110716p5-1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/binutils-msp430_2.22~msp20110716p5-1_i386.deb (--unpack):
 trying to overwrite '/usr/bin/msp430-strip', which is also in package msp430-binutils-tinyos 2.21.1-20110821
Please let me know if you need more information (I don’t know what to provide at this point).
karel
  • 122,292
  • 133
  • 301
  • 332
Dumbo
  • 1,962
Run this to remove the older gcc compiler
sudo apt-get remove gcc*
and then
blade19899
  • 26,994
