I'm having problems loading a zenity List Dialog when the data contains spaces.
It is straight-forward when there are no spaces in the listed data,
but I don't know of a simple/standard method for space-embedded file names.
For some reason, the output of $(ls -Q /tmp) (Quoted output) still
splits the file-names at every space. The quotes and back-slashes in the
ls | sed output seem to be treated as a "finalized string" rather than
as "readable data lines" (like the first two data lines)...
I've managed to "work around the issue", but Self-Modifying code probably
isn't the best way to go! (even though it is fun! :)
Here is the method which does NOT work
zenlist="/tmp/zen list"; touch "$zenlist"
zenity --list --title='A single-column List' --width=600 --height=450 \
--column='Spaces are allowed within "q u o t e s"' \
"How much wood would a woodchuck chuck," \
"if a wooodchuck could chuck wood?" \
$(ls -Q -1 "$zenlist"* |sed 's/$/ \\/')
echo ""
# rm "$zenlist"  # Uncomment this line to delete the file
This method works, but there must be a "conventional" (better) way!?
echo "zenity --list --title='A single-column List' --width=600 --height=450 \\" >"$zenlist"
echo "--column='Spaces are allowed within \"q u o t e s\"' \\"       >>"$zenlist"
echo "\"How much wood would a woodchuck chuck,\" \\"       >>"$zenlist"
echo "\"if a wooodchuck could chuck wood?\" \\" >>"$zenlist"
(ls -Q "$zenlist"* |sed 's/$/ \\/')   >>"$zenlist"
echo "" >>"$zenlist"
source "$zenlist"
Peter.O
  • 25,251
The problem is ls. It was never designed to be used in scripts. Besides, it's also pointless to use ls in scripts, because the shell can do the job much better, by simply using a glob, see http://mywiki.wooledge.org/BashGuide/Patterns
zenlist="/tmp/zen list"; touch "$zenlist" "$zenlist"$'\neven with a newline'
       "$zenlist"*
And for a general way to put list items with spaces and other chars into a "variable", use bash arrays.
# assign some items to start with
items=( "How much wood would a woodchuck chuck," "if a wooodchuck could chuck wood?" )
# append some items
items+=( "$zenlist"* )
       --column='Spaces are allowed within "q u o t e s"' "${items[@]}"
geirha
  • 47,279
You can pipe the list content into zenity, like
(echo "How much wood would a woodchuck chuck," ; \
 echo "if a wooodchuck could chuck wood?" ; \
 ls -Q -1 "$zenlist"* |sed 's/$/ \\/') \
