Yesterday night I was trying to download Java as per instructions given on http://developer.android.com/ .But I messed up somewhere and had to give up the thing. But since morning when ever I try to install or remove some thing I get the following response http://paste.ubuntu.com/1198084/
Please help fast. I am a newbie in android development and have to submit an app within 5 days from now for a project. And I need my linux machine working fine for that.
A clean install needed. Follow these steps
Download jdk-7u7-linux-i586.tar.gz and put it in your Desktop folder.
Open a terminal and type
sudo apt-get purge openjdk-\*
sudo mkdir -p /usr/local/java
cd ~/Desktop
sudo -s cp -r jdk-7u7-linux-i586.tar.gz /usr/local/java
cd /usr/local/java
sudo -s chmod a+x jdk-7u7-linux-i586.tar.gz
sudo -s tar xvzf jdk-7u7-linux-i586.tar.gz
sudo gedit /etc/profile then copy and paste this at the bottom of the document
Then run these command to set java as default for your system.....
sudo update-alternatives --install "/usr/bin/javac" "javac" "/usr/local/java/jdk1.7.0_07/bin/javac" 1
sudo update-alternatives --set javac /usr/local/java/jdk1.7.0_07/bin/javac
. /etc/profile
Then check your Java version with java -version
Kaktarua
  • 1,934
Ohk so thanks @Kaktarua for your help but I realized my mistake. Yesterday night when I was trying to install Sun JDK - Java I messed up somewhere and so it was only half-installed (ohk I don't know the right term for it.)
So whenever I tried to install or remove something, the apt program tried to install the java thing as well once it had installed the current program.
So I had to remove java stuff from the list of queued downloads. That I did using
gksudo gedit /var/lib/dpkg/info/oracle-java7-installer.prerm*
Add "exit 0" to first line, save file and close gedit. Then type
sudo dpkg -P oracle-java7-installer
I searched on Ask Ubuntu and came across this answer which proved very helpful:
