I recently installed Ubuntu 12.04 LTS on my SONY VAIO VPCEH (with Windows 7 Home Basic
previously installed). Sometimes when I boot in Ubuntu, following things happen:
  • Ubuntu loading screen seems to freeze.
  • Esc key doesn't show installation progress.
  • Hard-drive led doesn't glow.
  • caps lock and scroll lock keys keep blinking.
I've to manually restart my laptop. On restart, Ubuntu loads normally.
What can I do to recover from present situation?
mohit
  • 198
This sounds like a IRQ Conflict Problem. But could also be a kernel Panic Problem. You should try to add some boot parameters and check if they might help. You can add those to the grub menu.
More here:
Boot Options (English)
Boot Parameters (German)
I sometimes had to use the following: (even in combination)
irqpoll
noapic, noagp, noapm
nolapic
pci=noacpi
pci=routeirq
Peterling
  • 1,169
In some cases it's only just a lock screen problem and easy to bypass: just try CTRL+ALT+F8.
What is happening is that system is running properly, as one can see by login from CTRL+ALT+F1 virtual terminal (VT) or from a remote terminal, but the lock screen at VT7 , obtained by CTRL+ALT+F7 is freezed due to a light-locker screensaving program function who moves to the next VT8.
Forfurther details see Screen Locking in Xubuntu
kelvinelove
  • 1,619
