I'm trying to get to my phone's filesystem through USB in Wammu, but I'm stuck in the configuration wizard when it asks for a USB device name. After about an hour of Internet searching, here are the failed solutions I've already tried, starting with the relevant information returned by lsusb in terminal.
lsusb
Bus 001 Device 003: ID 12d1:101e Huawei Technologies Co., Ltd.
So I tried opening Wammu through sudo wammu in terminal and inputting "/dev/bus/usb/001/003" as the device name, which returns:
Error opening device
Device /dev/bus/usb/001/003 does not exist!
and then "/dev/bus/usb/001/", which returns:
Failed to connect to phone
Description: Error opening device. Unknown, busy, or no permissions.<br>
Function: Init<br>
Error code: 2
Another proposed solution was to try "tail -f /var/log/messages" in terminal. But that only returned a "No such file or directory" message.
Seemingly relevant dmesg info:
[ 4739.716214] usb 1-1: new high-speed USB device number 8 using ehci_hcd
[ 4739.854137] scsi9 : usb-storage 1-1:1.0
[ 4740.854416] scsi 9:0:0:0: CD-ROM            HUAWEI T Mass Storage     2.31 PQ: 0 ANSI: 2
[ 4740.867051] sr0: scsi-1 drive
[ 4740.867806] sr 9:0:0:0: Attached scsi CD-ROM sr0
[ 4740.870464] sr 9:0:0:0: Attached scsi generic sg1 type 5
I don't know why it is coming up as CD-ROM. But there it is.
If you haven't noticed already, I'm an absolute beginner when it comes to Linux and terminal. So speaking to me like I'm a three year old is welcome if you can propose a solution.
I'm running Ubuntu 12.04 LTS, and the phone is a Huawei U1250. My computer is an Acer Aspire One D250/KAV60. Any help is much appreciated.
Paul
  • 161
you should try
gammu-detect
Wammu is command line variant of Gammu,you'd know that.
This will give you a config file gammu you can find the device name in it.
Note the first two devices!
Ex)
dave@hnphp006:~$ gammu-detect
; Configuration file generated by gammu-detect.
; Please check The Gammu Manual for more information.
[gammu]
device = /dev/ttyACM0
name = Sony_Ericsson Sony_Ericsson_K790
connection = at
[gammu1]
device = /dev/ttyACM1
connection = at
[gammu2]
device = /dev/ttyS0
name = Phone on serial port 0
connection = at
[gammu3]
device = /dev/ttyS1
name = Phone on serial port 1
connection = at
... etc..
ganesh
  • 151
You will find mounted removable media in /media. The directory used in /media will usually be the volume name, or the UUID (a long serial number) if there isn't one. This would be the filesystem.
I'm not sure the filesystem is exactly what Wammu wants however. If it really is looking for the device name, and if the device really is being recognised as as a CD-ROM, then the device name should apparently be
/dev/sr0
To get a list of device names on your system you should use the bash command:
blkid
fabricator4
  • 8,471
  • 37
  • 39
