I was trying to fix plymouth using a script I found, the /etc/initramfs-tools/modules file is now empty!
So I don't know what this can means for my system. Can anyone help me restoring it?
Anwar
  • 77,855
Hoghweed
  • 211
The file /etc/initramfs-tools/modules is used to include modules in initramfs. This file has some lines which are commented out by default. That might means this file is effectively empty.
I am posting the default content of that file here. You may want to copy it and paste it in your files with a text editor and root privilege. To open the file with root power use sudo gedit /etc/initramfs-tools/modules command.
# List of modules that you want to include in your initramfs.
# They will be loaded at boot time in the order below.
# Syntax:  module_name [args ...]
# You must run update-initramfs(8) to effect this change.
# Examples:
# raid1
# sd_mod
If you add any modules name there, you need to run sudo update-initramfs -u command to update your currently used initramfs files.
I hope this helped you!
Anwar
  • 77,855
