Hope s.o. can help me ....
According to a page I found I should do this:
sudo add-apt-repository ppa:cinelerra-ppa/ppa
sudo apt-get update
sudo apt-get install cinelerra
But that led to the problem that the package "libmpeg3cine" could not be installed because some files were already installed by package "mpeg3-utils". The package system seemed broken because of a defective package. So I tried to uninstall it - which did not work. It worked only by running sudo gedit /var/lib/dpkg/status and removing the "cinelerra" section.
Then I tried to compile it according to the g-raffa compilation howto.
But this did not work until "make". Then I got the following errors:
collect2: ld gab 1 als Ende-Status zurück
make[3]: *** [x264] Fehler 1
make[3]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-4.3/quicktime/thirdparty/x264.052906'
make[2]: *** [x86_64/x264] Fehler 2
make[2]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-4.3/quicktime'
make[1]: *** [all] Fehler 2
make[1]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-4.3'
make: *** [all] Fehler 2
I even tried the newer version but that stopped earlier I think with the following error message:
/usr/bin/ld: .libs/libmpeg3.o: relocation R_X86_64_32 against `.rodata.str1.1' can not be used when making a shared object; recompile with -fPIC
.libs/libmpeg3.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[3]: *** [libmpeg3hv.la] Fehler 1
make[3]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-cv-old/libmpeg3'
make[2]: *** [all-recursive] Fehler 1
make[2]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-cv-old/libmpeg3'
make[1]: *** [all-recursive] Fehler 1
make[1]: Verlasse Verzeichnis '/home/peterl/system/cinelerra-cv-old'
As far as I know it says that I have to recompile with "-fPIC" So I tried to "configure" with:
./configure --with-buildinfo=git/recompile --enable-mmx --without-fpic --without-pic
But that seemed not to help as well. I also tried as mentioned with:
But that did not work as well.
Now I do not know what else I could try to get Cinelerra running.
Maybe there is another howto? Hope Someone can help me please.
