64
In Windows, applications are installed into Program Files folder by default. I have recently installed MS Office using Wine.
Where are apps installed with Wine? Can I decide in which folder should they be installed?
Himjyoti Malakar
  • 731
Wine has a root directory .wine in your home directory. The windows-drive letters (e.g.: C: D: ..) can be mapped with the winecfg program. Depending on what drive letter you installed MS office you find the files somewhere under the .wine directory.
most commonly your installation is in ~/.wine/drive_c/Program\ Files\ \(x86\)...
user61664
  • 961
The Program Files folder are in /home/YOUR USERNAME/.wine/
if the setup program of a application allows you to choose a different folder then u can
blade19899
  • 26,994
As pointed in previous anwsers the default folder is ~/.wine
If .wine folder doesn't exist, it means you need to run winecfg first
This script creates ~/.wine/drive_c folder and shows a option pane from where you should set the Windows version to use (10, 8 and 7).
Now you can download a .exe file and place it in .wine/drive_c/binaries
For example, you can install python with the following command::
cd ~/.wine/drive_c/binaries
wine python-3.10.7-amd64.exe
Test if python was installed:
wine ~/.wine/drive_c/users/<username>/AppData/Local/Programs/Python/Python310/python.exe
Savrige
  • 323
