I would know how to remove or hide in Ubuntu 12.04 the Chat Status section (available, away, busy, invisible and offline) from Messaging Menu as I am not using any instant messenger. I do not want to remove the entire menu, just that section.
Thank you very much and best regards!!
Chat status section screenshot
Seth
  • 59,332
user44849
  • 109
FOR 12.04
If you're using 13.10 or newer see here..
Its possible...
pic
As you can see the status section has been removed leaving just the Broadcast and Mail sections
To put a positive spin - open-source means you have direct access to the actual source-code. You can interrogate and change the code ... as long as you give back the code changes to others!
So here goes - the following demonstrates the code changes that are required to the package indicator-messages
prerequisites
Lets get source packages from the repository:
sudo apt-get build-dep indicator-messages
apt-get source indicator-messages
This will create a folder - name will change depending upon the package version of indicator-messages. For 12.04 this folder is indicator-messages-0.6.0
code changes
Two modules in the folder indicator-messages-0.6.0 will need changing.
cd indicator-messages-0.6.0/src
status-items.c
Using your favourite editor add the line return NULL; at or around line 80 in the function "status_items_build" shown:
pic2
messages-service.c
At or around line 893 in the function "resort_menu" comment out the code shown with /* and */
pic3
lets compile
To compile this, move up to the parent folder
cd ..
Compile, make and install:
./configure
make
sudo make install
Logout and login.
to undo
To undo your changes:
sudo make uninstall
sudo apt-get --reinstall install indicator-messages
fossfreedom
  • 174,526
For 13.10
If you're using for 12.04 see here.
Almost same steps in How to remove (or hide) Chat Status Icons from Messaging Menu
  • Install build prerequisites
  • Download source archive
  • Modify src/im-desktop-menu.c, add /* and */ to comment non needed menu as it is shown here:
    static GMenu *
    create_status_section (void)
      GMenu *menu;
      GMenuItem *item;
        g_object_unref (item);
        return menu;
        GMenu *status_section;
        status_section = create_status_section();
        im_menu_append_section (IM_MENU (menu), G_MENU_MODEL (status_section));
        g_object_unref (status_section);
    To remove Clear menu item too:
        GMenu *clear_section;
        clear_section = g_menu_new ();
        g_menu_append (clear_section, _("Clear"), "indicator.remove-all");
        im_menu_append_section (IM_MENU (menu), G_MENU_MODEL (clear_section));
        g_object_unref (clear_section);
  • Compile
    ./autogen.sh
    ./configure
    make
  • Install
    sudo make install
    Or like me I just replace it, without un-installing original (I use 64bit):
    Backup original
    sudo mv /usr/lib/x86_64-linux-gnu/indicator-messages/indicator-messages-service /usr/lib/x86_64-linux-gnu/indicator-messages/indicator-messages-service_orig
    Copy the new compiled version
    sudo cp ./src/indicator-messages-service /usr/lib/x86_64-linux-gnu/indicator-messages/indicator-messages-service_mod
    Create a link to the new compiled version
    sudo ln -s /usr/lib/x86_64-linux-gnu/indicator-messages/indicator-messages-service_mod /usr/lib/x86_64-linux-gnu/indicator-messages/indicator-messages-service
For 14.04
Same steps as 13.10 with different modifications
    static void
    menu_append_status (GMenu       *menu,
                                const gchar *label,
                        const gchar *detailed_action,
                        const gchar *icon_name)
      GMenuItem *item;
      GIcon *icon;
      g_object_unref (icon);
    static void
    im_desktop_menu_show_chat_section (ImDesktopMenu *menu)
      menu->status_section_visible = TRUE;
      if (g_desktop_app_info_get_boolean (app_info, "X-MessagingMenu-UsesChatSection"))
        im_desktop_menu_show_chat_section (menu);
user.dz
  • 49,176
You can remove the indicator-messages package from software center for completely remove it or see this link to configure it for your needs .
