Possible Duplicate:
Installing packages in multiple systems
We are planning to install around 15 machines with desktop version and we need same software on all machine. Can you suggest best approach to save time? We are not much technical and we install software by going to software manager, we just need to avoid this as it takes lots of time to download all software each time.
Thanks
user86296
If I understand your question correctly, you want to install an OS, and other software clone it, and install the same exact on 15 machines. If that's the case, the you can use clonezilla. There is a limitation of (The destination partition must be equal or larger than the source one).
Clonezilla is a partition or disk clone tool similar to Norton Ghost®. It saves and restores only used blocks in hard drive. Two types of Clonezilla are available: Clonezilla live and Clonezilla SE (Server Edition). While Clonezilla SE is for massive deployment, it can clone many (40 plus!) computers simultaneously. Clonezilla saves and restores only used blocks in the harddisk.1
You can Download clonezilla, burn it to a CD, and you're ready to roll.
1Source:Clonezilla
wakeup
  • 955
Mitch
  • 109,787
You can first download all the *.deb files and the dependencies. Then you can install them in all computers by the command:-
sudo dpkg -i filename_1.deb filename_2.deb
Here filename_1.deb and filename_2.deb represent the files that you have downloaded. This will save your downloading time but the installing time will remain the same!
Pranit Bauva
  • 1,101
If the software are available in the official Ubuntu 12.04 repository,
you can easily download them via command line like so
example:
sudo apt-get --download-only install firefox
sudo means give root(admin) right to a user/application and you need to give a password
apt-get is the program that downloads and or install the applications
and when downloaded, run this command to install them silently
sudo dpkg -i *.deb
blade19899
  • 26,994
