Possible Duplicate:
Why can't I install Ubuntu or Wubi on a dynamic disk? (“The request isn't supported” from bcdedit.exe)
An error occurred:
Error executing command
command=C:/windows/system32/bcdedit.exe/set{aaf19def-e9a5-11e1-86de-9f7ceafcb45f} device partion=D:
..retval=1
..stderr=An error has occurred setting the element data.
The request is not supported.
..stdout=
For more information, please see the log file: C/users/admin/appdata/local/tem/wubi-12.04-rev265.log
Please help me solve the problem.
user87854
Please install as boot, First try ubuntu. If it works properly you can install it. If no, may be your hard has not a good partition. you have to format all and change it to 3part only while installing.
Behnam
