I just successfully upgraded from 10.04 to 12.04, and these instructions appear to be exactly what I want. However, for the life of me, I cannot find Thunderbird's tools menu to import my Evolution email.
I am using Thunderbird installed as part of the 12.04 upgrade, and the Thunderbird global menu package is installed. I checked. I cannot find how to indicate what version Thunderbird is other than it was installed as part of 12.04.
Thanks.
Another possibility is that the menu bar got disabled. Right-click on the free space next to the "Inbox" tab and select "Menu Bar" if there is no check symbol.
Pat
  • 61
Generally to get the menu items, we need to install global menu
sudo apt-get install thunderbird-globalmenu
Since you have already installed this, I think the problem should be with your thunderbird.
To fix this issue can you try removing the Thunderbird version that is currently installed. and add the ppa provided by mozilla team using
sudo apt-add-repository ppa:ubuntu-mozilla-security/ppa
and install Thunderbird new version (v15 I guess).
If the above works then you should be able to access the tools from global menu
devav2
  • 37,290
Tools was there all along. With this version of Ubuntu (12.04) I did not realize that Unity-behaving applications appear to use a common menu at the top of the screen. Problem solved.
