I have a 1TB external hard drive that I recently formatted to NTFS. It was mounting on my Ubuntu 11.10 fine until just now. I didn't make any changes to affect my OS or my exhdd.
The error that I get is:
Error mounting: mount exited with exit code 13: $MFTMirr does not match $MFT (record 0).
Failed to mount '/dev/sdb2': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.
I did read this and this. But neither helped.
I tried installing ntfsfix but no such package exists anymore.
I have never used this HDD on a windows machine. If I need to use an other machine to do stuff to fix this, I have access to a mac.
Any advice?
This is my sudo fdisk -l output: What in the world is GPT? I didn't do that. It used to be NTFS.
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000586fb
Device Boot Start End Blocks Id System
/dev/sda1 * 2148 961320312 480659082+ 83 Linux
/dev/sda2 961320313 976773167 7726427+ 5 Extended
/dev/sda5 961320314 976773167 7726427 83 Linux
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0xcfd88605
/dev/sdb1 1 1953525167 976762583+ ee GPT
