Possible Duplicate:
Wireless doesn't work on a Broadcom BCM4312
sir i have problem with my wifi switch
sir please tell me solution for my problem (wifi is disabled by hardware).
output of sudo lshw -C network is
   sudo] password for sudheer:
  *-network DISABLED
       description: Wireless interface
       product: BCM4312 802.11b/g LP-PHY
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: eth2
       version: 01
       serial: 00:21:00:72:3a:93
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=wl0 driverversion=5.100.82.38 latency=0 multicast=yes wireless=IEEE 802.11bg
       resources: irq:19 memory:f4700000-f4703fff
  *-network
       description: Ethernet interface
       product: NetLink BCM5906M Fast Ethernet PCI Express
       physical id: 0
       bus info: pci@0000:07:00.0
       logical name: eth0
       version: 02
       serial: 00:1e:68:ad:24:0b
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.121 duplex=full firmware=sb v3.04 ip=172.16.52.79 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:47 memory:f4600000-f460ffff
output of iwconfig is
lo        no wireless extensions.
eth2      IEEE 802.11  Access Point: Not-Associated
          Link Quality:5  Signal level:0  Noise level:0
          Rx invalid nwid:0  invalid crypt:0  invalid misc:0
eth0      no wireless extensions.
sudheer@sudheer:~$ sudo iwlistscanning
sudo: iwlistscanning: command not found
***sudheer@sudheer:~$ sudo iwlist scanning***
lo        Interface doesn't support scanning.
eth2      Failed to read scan data : Invalid argument
eth0      Interface doesn't support scanning.
sudheer
Try with command. Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the command below.
rfkill unblock all
Mitch
  • 109,787
