Looks like I have a problem that has already been debated but non of the solutions provided did not work for me, so I'm asking this question again in hpes that someone can help me.
I'm running 12.04 64 bit version on Lenovo E520 with AMD Radeon HD 6600M and Intel HD graphic. I was using catalyst 12.6 driver downloaded and installed from http://support.amd.com/us/gpudownload/windows/previous/12/Pages/radeon_linux.aspx?os=Linux%20x86&rev=12.6.
However my system unexpectedly crashed with the "your system is running in low graphic card error". Since than I've removed the old ATI driver and installed the 12.8 version following their instructions with no problems, however the error still remains. If I use open source drivers I can use Ubuntu, but it slow to the point I can't even use gnome 3.
Previous solutions described do not work for me: How do I fix "Your system is running in low-graphics mode"?
Any help?
From the AMD wiki support site:
There are two basic types of hybrid designs. Older hybrid systems use a multiplexor (mux) to switch between GPU's. Newer systems (those with PowerXpress >= 4.0) are muxless. As far as I can tell, PowerXpress 4.0 started with RadeonHD 6000-series GPU's, and systems with older ATI GPU's have a mux, but don't quote that.
Intel/ATI Hybrids
TODO: Status unknown at this time
That line in 12.6 used to say that it was not possible to use Intel/AMD hybrid adapters with the fglrx drivers.
The best you can do is use the open source drivers or investigate further inside your BIOS and check if you can disable the Intel card completely.
Bruno Pereira
  • 74,715
