In a background Python script I need to detect, when the system just woke up from suspend. What is a good way that does not rely on a root script but rather on python modules such as DBus?
I'm new to dbus so I could really use some example code. From what I read it's related to
org.freedesktop.UPower /org/freedesktop/UPower org.freedesktop.UPower.Resuming
Can anyone help me out with some code that connects the resuming signal to callback?
con-f-use
  • 19,041
Here is some example code that answers my question:
#!/usr/bin/python
# This is some example code on howto use dbus to detect when the system returns
#+from hibernation or suspend.
import dbus      # for dbus communication (obviously)
import gobject   # main loop
from dbus.mainloop.glib import DBusGMainLoop # integration into the main loop
def handle_resume_callback():
    print "System just resumed from hibernate or suspend"
DBusGMainLoop(set_as_default=True) # integrate into main loob
bus = dbus.SystemBus()             # connect to dbus system wide
bus.add_signal_receiver(           # defince the signal to listen to
    handle_resume_callback,            # name of callback function
    'Resuming',                        # singal name
    'org.freedesktop.UPower',          # interface
    'org.freedesktop.UPower'           # bus name
loop = gobject.MainLoop()          # define mainloop
loop.run()                         # run main loop
See the dbus-python tutorial.
con-f-use
  • 19,041
The login1 interface provides the signal now. Here is the modified code:
#!/usr/bin/python
# slightly different code for handling suspend resume
# using login1 interface signals
def handle_sleep_callback(sleeping):
  if sleeping:
    print "System going to hibernate or sleep"
  else:
    handle_sleep_callback,            # name of callback function
    'PrepareForSleep',                 # signal name
    'org.freedesktop.login1.Manager',   # interface
    'org.freedesktop.login1'            # bus name
Nimar
  • 211
