10
I really don't like firefox, so the first thing I did after installation was install chromium as a browser and removed firefox via terminal using:
sudo apt-get remove --purge firefox
But every time update manager opens it lists language packs for firefox. I can uncheck the package, but it gets rather annoying.
Is there some lingering file somewhere that I need to purge as well?
Jorge Castro
  • 73,717
Avie Rose
  • 101
Remove the firefox and all the associated language packs with this command
sudo apt-get --purge autoremove firefox
It should remove firefox and all language packs for it. The output in my computer is shown below:
anwar@edubuntu-lenovo:~$ sudo apt-get autoremove firefox
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  firefox firefox-globalmenu firefox-gnome-support
Your output may vary depending on the packages you installed. The important thing is you should see the uninstallation of these packages
Using autoremove uninstall packages which was required by firefox but is not required now after removing it. Without autoremove those packages will be left on system.
autoremove: removes any packages on your system that are no longer needed. As an example if I install package A, it might install packages B and C as dependencies. Simply un-installing package A doesn't automatically un-install packages B and C as well, they are left installed. apt-get autoremove searches your system for packages that have been installed as dependencies but are no longer used and removes them.
See this apt-get manual page for more info.
Hope this helps.
Anwar
  • 77,855
In a terminal you can list firefox related packages.
dpkg --list | grep firefox
Uninstall the unwanted packages.
BuZZ-dEE
  • 14,533
Try this one, should work fine
sudo apt-get --purge autoremove firefox-locale-en unity-scope-firefoxbookmarks xul-ext-webaccounts
sudo rm -rf ~/.mozilla
