Possible Duplicate:
Wireless doesn't work on a Broadcom BCM4312
As per subject, I've looked at various resources and attempted ndiswrapper solutions, found a one-click solution that lead to a 404 and this but none works.
I've run all updates. Once I managed to lose my wired connection as well and had to reinstall. This is my first hour with Linux.
iwconfig gives this before I do anything:
lo no wireless extensions.
wlan0 IEEE 802.11bg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Power Management:on
eth0 no wireless extens
Thanks for responding lspci returns
00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 03)
Subsystem: Dell Device 01c9
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03) (prog-if 00 [VGA controller])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at dff00000 (32-bit, non-prefetchable) [size=512K]
Region 1: I/O ports at eff8 [size=8]
Region 2: Memory at c0000000 (32-bit, prefetchable) [size=256M]
Region 3: Memory at dfec0000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at <unassigned> [disabled]
Kernel driver in use: i915
Kernel modules: intelfb, i915
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
Latency: 0
Region 0: Memory at dff80000 (32-bit, non-prefetchable) [size=512K]
00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 03)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 42
Region 0: Memory at dfebc000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd-hda-intel
00:1c.0 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 1 (rev 03) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 30000000-301fffff
Prefetchable memory behind bridge: 0000000030200000-00000000303fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1c.3 PCI bridge: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) PCI Express Port 4 (rev 03) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=0c, subordinate=0d, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: dfc00000-dfdfffff
Prefetchable memory behind bridge: 00000000d0000000-00000000d01fffff
00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03) (prog-if 00 [UHCI])
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 4: I/O ports at bf80 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin B routed to IRQ 17
Region 4: I/O ports at bf60 [size=32]
00:1d.2 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin C routed to IRQ 18
Region 4: I/O ports at bf40 [size=32]
00:1d.3 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03) (prog-if 00 [UHCI])
Latency: 0
Interrupt: pin D routed to IRQ 19
Region 4: I/O ports at bf20 [size=32]
00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03) (prog-if 20 [EHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at b0000000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d3) (prog-if 01 [Subtractive decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: dfb00000-dfbfffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 03)
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel modules: iTCO_wdt, intel-rng
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03) (prog-if 8a [Master SecP PriP])
Latency: 0
Region 0: I/O ports at 01f0 [size=8]
Region 1: I/O ports at 03f4 [size=1]
Region 2: I/O ports at 0170 [size=8]
Region 3: I/O ports at 0374 [size=1]
Region 4: I/O ports at bfa0 [size=16]
Kernel driver in use: ata_piix
02:00.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
Latency: 64
Interrupt: pin A routed to IRQ 18
Region 0: Memory at dfbfc000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: b44
Kernel modules: b44
02:03.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
Subsystem: Dell Wireless 1370 WLAN Mini-PCI Card
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 64
Interrupt: pin A routed to IRQ 17
Region 0: Memory at dfbfe000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: b43-pci-bridge
Kernel modules: ssb
and the rfkill shows
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Just checking addtional drivers. Says no additional driver installed in this system
