10
I restarted my computer, and when I logged back in, I noticed that all of my files that were on the desktop are gone. Instead, icons of all of my home folder are showed on my desktop.
I opened the terminal and found out that there is no ~/Desktop folder.
What happened? What do I need to do?
12.04 32-bit WUBI installed.
Braiam
  • 69,112
Greg
  • 101
6 Answers6
11
You need to edit the ~/.config/user-dirs.dirs file. Make sure the contents of the file are like the following:
XDG_DESKTOP_DIR="$HOME/Desktop"
XDG_DOWNLOAD_DIR="$HOME/Downloads"
XDG_TEMPLATES_DIR="$HOME/"
XDG_PUBLICSHARE_DIR="$HOME/Share"
XDG_DOCUMENTS_DIR="$HOME/Documents"
XDG_MUSIC_DIR="$HOME/Music"
XDG_PICTURES_DIR="$HOME/Pictures"
XDG_VIDEOS_DIR="$HOME/Videos"
Then restart nautilus:
killall nautilus
or
nautilus -q
Then, open nautilus via Unity menu (press the Super key) or using the run command (Alt+F2)
green
  • 14,406
I had the same problem with missing ~/Desktop folder.
After a routine upgrade to Ubuntu 20.04.2 LTS, my /home//Desktop directory was gone and all folders and files from my home directory appeared on my desktop.
I recreated the Desktop directory and updated the ~/.config/user-dirs.dirs file as answered by user green above.
This worked for me, with my desktop back to normal.
I faced the same issue yesterday and the following commands did the trick;
gconftool-2 --recursive-unset /apps/compiz-1
unity --reset &
But mine is a general install, not through WUBI.
I was also having similar issues. What I see went wrong is my $HOME variable is pointing to /tmp instead of /home/username.
Seth
  • 59,332
Patrick
Thanks, for GNOME desktop on Ubuntu 22.04 I recreated missing folders manually with terminal, just:
cd ~
mkdir Videos Documents
and all missing folders + use config that is provided up above. Thanks!
Create a directory to the desktop if it is deleted. Then edit the configuration file for Nautilus and specify the path to it. Reboot PC.
