Just installed 12.04 32 bit on my machine, with 3 drives. When I open a terminal window or ssh in remotely, I see:
Welcome to Ubuntu 12.04.1 LTS (GNU/Linux 3.2.0-29-generic-pae i686)
 * Documentation:  https://help.ubuntu.com/
*** /dev/sda1 will be checked for errors at next reboot ***
*** /dev/sda2 will be checked for errors at next reboot ***
*** /dev/sdg1 will be checked for errors at next reboot ***
Last login: Fri Aug 31 08:15:41 2012 from ....
However, if I reboot, I never see it doing a disk check on boot up, like I used to see with 10.10. Note, after install, I was not seeing the grub menu on boot. I made a ISO disk with BootRepair and now I get the normal grub menu.
Any idea as to why the disk check is not happening on boot (I know I can boot a Live CD and then check the disk - I just want the check on boot working)?
pcm
  • 386
