22
Welcome,
Currently I'm trying to install latest uwsgi on my VPS (Ubuntu 11.10) based on instruction from the site http://projects.unbit.it/uwsgi/wiki/Quickstart
pip install uwsgi
During compilation I see some errors:
[gcc -pthread] spooler.o
*** uWSGI compiling embedded plugins ***
[gcc -pthread] plugins/python/python_plugin.o
Complete output from command /usr/bin/python -c "import setuptools;__file__='/etc/apt/sources.list.d/build/uwsgi/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-joud1I-record/install-record.txt:
running install
In file included from plugins/python/python_plugin.c:1:0:
plugins/python/uwsgi_python.h:2:20: fatal error: Python.h: No such file or directory
compilation terminated.
using profile: buildconf/default.ini
detected include path: ['/usr/lib/gcc/i686-linux-gnu/4.6.1/include','/usr/local/include', '/usr/lib/gcc/i686-linux-gnu/4.6.1/include-fixed', '/usr/include/i386-linux-gnu', '/usr/include']
Patching "bin_name" to properly install_scripts dir
And finally I see:
Command /usr/bin/python -c "import setuptools;__file__='/etc/apt/sources.list.d/build/uwsgi/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-joud1I-record/install-record.txt failed with error code 1 in /etc/apt/sources.list.d/build/uwsgi
Storing complete log in /root/.pip/pip.log
Has anyone any suggestions how can I install latest uwsgi?
Regards, Grzegorz
Gie
  • 345
To compile C extensions for Python you need Python development files:
$ sudo apt-get install python2.7-dev
jfs
  • 4,078
Just so will be here in case someone else comes across this problem:
Even though we had installed python2.7-dev successfully we still got this error.
What apparently was the problem was gcc's inability to find the libraries which were included in the build script pip was trying to run.
We actually ended up getting the uwsgi pip zip:
and then changing it manually like with the following steps.
First, we unzipped it:
tar xvzf uwsgi-1.9.20.tar.gz
Then, we edited the file uwsgiconfig.py, replacing line 213,
cmdline = "%s -c %s -o %s %s" % (GCC, cflags, objfile, srcfile)
To say this instead:
cmdline = "%s -I/usr/include/libxml2 -c %s -o %s %s" % (GCC, cflags, objfile, srcfile)
Basically, letting gcc know that your libraries are at /usr/include/libxml2 (this was our case at least).
After that, we rezipped the folder:
tar cvf uwsgi-1.9.20.tar uwsgi-1.9.20/
gzip uwsgi-1.9.20.tar
And used pip with that gzip file:
sudo pip install uwsgi-1.9.20.tar.gz
And that worked. Hope that helps someone!
Eliah Kagan
  • 119,640
wilfo
  • 321
To install under Cygwin via pip, need the following packages:
  • gcc-core
  • gcc-g++ (probably)
  • libcrypt-devel
  • libintl-devel
  • python3
  • python3-devel
tivnet
  • 99
