I have installed Ubuntu 12.04 on my EeePC 1015PX and I've noticed that the CPU temperature does not go below 60ºC (70 is usual). Looking at powertop it seems the 2 cores (Atom N570) are idle most of the time. I've installed jupiter (w/ jupiter-eee-support) but it did not help.
Edit: Meanwhile I've found out that echo 2 > /sys/devices/platform/eeepc-wmi/cpufv is supposed to turn on Super Hybrid Engine. Though it seems to help a bit (temperature goes down 2-3ºC), the temperatures are still in the 60-70ºc range.
nmc
  • 71
My experience with Linux on laptops is that it will run hotter and have less battery life than the OS it came with :( I use Ubuntu exclusively on my desktop but I probably won't try again on the laptop for a long time.
To answer the question: if you want to lower the CPU temperature, you can underclock the processor. This will make your computer slower, though. This guide might be helpful.
My ASUS laptop runs fine and the temps are same as in Win7 with all the ASUS bloat added. If temps worry you, invest in a laptop cooler.
Arup Roy Chowdhury
  • 1,580
