I use the default backup utility of ubuntu (deja-dup) in the settings panel. Today I delete by error one directory. I tried to restore it but I did not succeed. Must I restore all my backup if I only need one single directory or file ?
Thanks.
Of course you can do that. From the gnome DejaDup Help wiki (oh and where it says file you can also read directory)
Note that for Ubuntu you'll need the ubuntuone-client package installed in order for the menu entries to appear in Nautilus, even if you're not using Ubuntu One.
Also note that Mate's version of Nautilus, Caja, does not support restoring files.
You can revert files on the command line:
deja-dup --restore FILE1 FILE2
The above answer did not work for me as the drive that had originally been backed up had been removed. I share the procedure I followed below:
duplicity list-current-files --no-encryption file:///[path_to_backup_folder] > /home/[your_username]/list.txt
Be aware of the format "file:///..." in which duplicity expects to receive path to archive - You need to indicate the full path to the folder containing your backup.
mkdir [PATH AND FILENAME FOR RESTORED FILE]
duplicity restore --no-encryption --file-to-restore [PASTE RESULTS FROM PREVIOUS STEP] file:///[LOCATION OF BACKUP] [PATH AND FILENAME FOR RESTORED FILE]
Please note that the commands will be different for an encrypted backup. Check reference below.
Caja user here, (Mate on 16.04.3). Problems with these solutions for me, FWIW.
"Backup" a.k.a. "deja dup" (note to developers: standardizing a name is really helpful when a newbie has to go looking for answers) won't allow me to do anything other than a full extraction of my whole backup to a location of my choosing. I just want one little directory for a malfunctioning VM...
Used Nautilus. However, it doesn't have access to the directory I need (VBox. Me: "huh?"), so no restore function via GUI for me.
deja-dup --restore FILE1 FILE2 doesn't work. It complains:
** (deja-dup:3343): CRITICAL **: deja_dup_config_location_add_volume_full: assertion 'uuid != NULL' failed
Of course, I'm assuming that FILE1 is the backup and FILE2 the restoration target. If not, I goofed.
Regardless, it just launched the GUI to deja-dup - that's a no go.
$ duplicity restore --no-encryption file:///media/b/be5f7aad-aa52-47ea-8e64-4352111f66af/home/b/'VirtualBox VMs'/'Green Machine' 'VirtualBox VMs'/'Green Machine'
Local and Remote metadata are synchronised, no sync needed.
Last full backup date: none
Traceback (innermost last):
File "/usr/bin/duplicity", line 1559, in <module>
with_tempdir(main)
File "/usr/bin/duplicity", line 1545, in with_tempdir
fn()
File "/usr/bin/duplicity", line 1394, in main
do_backup(action)
File "/usr/bin/duplicity", line 1473, in do_backup
restore(col_stats)
File "/usr/bin/duplicity", line 729, in restore
restore_get_patched_rop_iter(col_stats)):
File "/usr/bin/duplicity", line 751, in restore_get_patched_rop_iter
backup_chain = col_stats.get_backup_chain_at_time(time)
File "/usr/lib/python2.7/dist-packages/duplicity/collections.py", line 984, in get_backup_chain_at_time
raise CollectionsError("No backup chains found")
CollectionsError: No backup chains found
A search engine of your choice will reveal others have this problem too over the years.
My work-around: "restore" everything to a 'holding folder' on my external drive via the GUI, manually go in and grab the directory I want, then zero-fill that folder.
