I have a SSD OCZ Vertex4 installed on my laptop. I'm running Ubuntu 12.04 LTS. I have enable TRIM by adding "discard" to my fstab file. (also added option noatime). I rebooted my Ubuntu and followed These instructions here to test TRIM. The end results of my tempfile was all ffff's, when it should have read all zero's, which is telling me TRIM is not really working or enabled correctly.
Did I miss something?
Also, will it be a problem if only my /home directory is encrypted.
AND if you ask why I have swap on my SSD, it's because I let Ubuntu set up my partition. When I received my SSD, I just wanted to install Ubuntu as fast as possible. =) I've done testing to see at which point it will start to use swap and it took a lot of applications open to finally use swap. I currently have 4 GB of memory. I might shrink this to like 512 MB or 1 GB the most.
Here's some info about my file system setup.
sudo hdparm -I /dev/sda1 | grep "TRIM supported"
Data Set Management TRIM supported (limit 16 blocks)
sudo fdisk -l /dev/sda
Device Boot Start End Blocks Id System /dev/sda1 * 2048 242016255 121007104 83 Linux /dev/sda2 242018302 250068991 4025345 5 Extended /dev/sda5 242018304 250068991 4025344 82 Linux swap / Solaris
ls /dev/mapper
control cryptswap1
M_M
  • 333
